EBCDIC-500 characterset format files can imported into Navision.
Can EBCDIC-500 character set format files be imported into Navision?
Ok, can they. Or is that a question?
And which version of Navision is this about? The last real Navision named version was Microsoft Business Solutions-Navision 5.0, released in 2005. And a lot has happened when it comes import of files since then.
Thank for the reply erik.
Is it possible to import EBCDIC-500 character set file format in Navision 2013?
Not directly. NAV doesn’t support EBCDIC natively.
But without having tried it, then I’m sure that you would be able to handle it using .Net controls, like System.Text, which supports EBCDIC and can be used from NAV.
