In the “old” classic versions, to see if a table was in use, the most easy way was to use
File → Database → Information → Tables
But is there an easy way in NAV 2013/2015 to do the same, without running SQL directly?
In NAV 2013 the Information → Tables functionality is still there, has from NAV 2013 R2 due to multi-tenant functionality.
Can you check if the report 104001 included in the upgrade toolkit is useful for your needing?
Daniele
Babrown,
Thank you. Sometimes the simpler solutions are the easiest!
