Hi, just a quickie If you have a backup with the application objects included you can import these objects directly without restoring the whole backup. In the Object designer choose import and select the .fbk instead of the suggested .fob or .txt. That’s it. Navision prepends the backup data with the objects if you included them during backup. Bye, Torsten
