Has anyone done a CRM upgrade to 9.1 recently. Where did you access the reg keys for 9.1? I can see the registration keys all the way up to CRM 2016 but don’t see 9.0 or 9.1 but I’m entitled to those keys.
Did you find these keys in partnersource or was where can I locate them? Microsoft support has told given mixed messages on the subject. They have said to look in partnersource and in the m365 admin center….? I have ask copilot and ChatGPT and they say m365 admin center but wanted to verify with someone here…
CRM licensing can be tricky; your confusion makes sense. Honest answer: sourcing a registration key depends on your subscription and agreement. I don’t want to steer you wrong.
What I’d do:
Contact Microsoft Support directly (get it in writing)
Check your CSP agreement if you’re working with a partner, keys are sometimes provisioned differently
If PartnerSource shows nothing for 9.0/9.1, that’s actually correct behavior (cloud versions work differently than on-premises)
That said, if you’re planning a CRM upgrade or migration, there’s usually more to solve than just keys. Infrastructure planning, version compatibility, data readiness - that’s where things get complex.
If you’re working through a migration and want a second opinion on the technical side, we’ve handled many CRM transitions and can help validate your approach.
