Dynamics Connector DateTime is less than minumum value supported by CrmDateTime
Using the Dynamics connector came across the following issue:
DateTime is less than minumum value supported by CrmDateTime. Actual value: 01/01/0001 00:00:00, Minimum value supported: 01/01/1900 00:00:00.
Mapping of DateTime field got this error :
Which data you are pushing from AX? (hope you are using the connector for AX)
The minimum data (or date null) in AX is also 01/01/1900. Check your data in AX or mapping.
Hi Kranthi,
thanks for the reply.
Yes i’m using Connector for AX.
I’m mapping DateTime field . In AX i have value for that field(EDT : JournalPostedDateTime) : 24-11-2017 14:49:58
But in connector its going as Null value . I tried MAP the same field to String field of CRM, it flowing as 01/01/0001 00:00:00 in CRM.
