Have any one work on the customization for axretail 2012 pos.
I want help in how to use the .net from the pos to insert the data in the AX.
Thanks.
Thanks.
hi there,
i have do customization in axretail 2012 pos using Retail SDK > POS Plug-ins > services
on that folder you will found visual studio solution for every feature on POS such as EFT, StockCount etc…
you can bind the solution to POS.exe and then do the debuging to see the process
