Dynamics AX Stock Report
I am looking a simple onhand inventory stock report quantity on hand with value of stock available.
Is any default report available in the system.
Is any one help in this regards?
Stock Management Module → Reports → On-Hand → On-Hand Stock…
You can filter on items etc or run off entire list.
  • Thanks I run this report but not getting value of inventory, its showing the quantity on hand but not value or cost price of inventory
Then I would suggest using this report and adding fields you require.
Not many reports in the system will have everything you need as standard - i.e. there are reports there which show stock value, but won’t show on hand stock :slight_smile:
Stock Management - Reports - Status - Physical Stock by Item Group (Quite a few in this node) - Gives you quantity and value.
