Dynamics AX: Cannot create a record in Indent Table
While creating the Indent, I am getting "CANNOT CREATE A RECORD IN INDENT TABLE(eisCFAReqJournalTable). CFA Req Id: IN12130699. The Record already exists.
Kindly guide me…
Insert is resulting in an unique index voilation, means you are trying to insert duplicate values…
Hi Nirupa,
Welcome to the user group.
Before you start posting you should really read this link:
http://dynamicsuser.net/content/how-to-ask-a-question.aspx
Always use a subject which actually tells what your issue is, not “ERROR !!! ERROR!!!” !
Also always write which product/version the issue is regarding!
You should check the datas you’re trying to insert into your table, check how is created the CFAReqId, ti seems that’s this record that’s problematic, when I see IN12130699, I would say that’s a problem with number sequence that create a new record for CFAReqId but I can mistake. If you show your code, I’ll tell you more
regards,
Thomas
Thanks for your reply…but here the number sequence is not increasing. While creating it is initialised to "IN12130699". kindly suggest me
did you try theGeneratedNumberSeq + 1 and insert? increasing manually seems stupid but it works most of time
Have a look at the class that generates the sequence, there must be some methods that deals and generates incremented sequences
regards,
Thomas
Dear Thomas,
I have checked for all , It is customized i AX3.0.
