[Atlas is a Add-IN in Excel that allows you to extract data from Dynamics AX database in a Excel spread sheet.]
For example, I have a view called Atlas_LedgerTrans:
- table 1: LedgerTrans
- table 2 : VendTrans
Is it possible to says that LEDGERTTRANS AS LEFT OUTER JOIN RELATION BETWEEN VENDTRANS ?
[a VIEW or a TABLE as to be use via the ATLAS Add-IN]
It seems that only INNER JOIN are permitted in the VIEWS, can we use LEFT OUTER JOIN ?
(I do the same query in SQL and we can use LEFT, RIGHT, INNER JOIN, whatever we want why not in AX)
Thanks in advance!
Carlos
