I am trying to install AOS Server locally with an existing SQL Server 2008 R2 . When i provide the database name and the next step is leading to following error
Property DbSqlServer set to: ‘(local)’
Connected to SQL Server: ‘(local)’
Exception: System.InvalidCastException
Message: Unable to cast object of type ‘System.DBNull’ to type ‘System.String’.
FullText: System.InvalidCastException: Unable to cast object of type ‘System.DBNull’ to type ‘System.String’.
at Microsoft.Dynamics.Setup.InstallSqlServer.GetDatabaseCollation(String databaseName)
at Microsoft.Dynamics.Setup.InstallSqlServer.ValidateDatabaseCollation(String databaseName)
at Microsoft.Dynamics.Setup.MainForm.s141_Next(Object sender, AxTabPageNextEventArgs e)
at Microsoft.Dynamics.Setup.AxTabPage.OkToContinue()
at Microsoft.Dynamics.Setup.MainForm.mainFormButtonNext_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
