Dynamics AX 2012 R2 VPC
Can someone please tell me if there is any way to download Dynamics AX 2012 R2 VPC if it is not available on partner source ?
Ash
When it is not available, you might check if you have participated in feedback on connect. There might be older files available for download. Otherwise you have to build your own VM. (probably download R3, remove the AX software and install R2.
