I have error when running payroll in dynamics ax 2009
Dynamics .NET Business Connector 5.0
Unable to connect to an Application Object Server. A server name may not be specified correctly in the client configuration, or the server specified may not be available.
I have checked Microsoft Dynamics AX 2009 Configuration every thing is ok. Connection of Bussiness Connector → Server : MYCOMPUTERNAME, Instance Name : DynamicsAx 1, TCP/IP : 2712
Please help me. Sorry for my english.
Thank in advance.
Tuan Hoang Anh
I am not familiar with payroll module. But looking at error message, it looks like it is a Business Connector (BC) issue. Can you try to test BC as mentioned in this article - http://www.axaptapedia.com/.NET_Integration?
I have added alias: bcproxy, domain erp.local in Setup->Security ->System service account-> Bussiness connector proxy
On the first, I had error in “2-it works”
Microsoft.Dynamics.BusinessConnectorNet.LogonFailedException: Logon error : You
are not a recognized user of Microsoft Dynamics AX. Contact your system administ
rator for help.
So, I add bcproxy to Users of Dynamics AX (Administrator → Common Forms → Users), and then 1,2 works well.
But, the error of payroll isn’t fixed.
Please help me.
Thanks you very much. Sorry my English is not well.
First set of try/catch is meant for testing from Visual Studio application. Second set is meant to be tried from web based application. Therefore there is no need to try both at one go.
