Hi !
By time to time, our team faces some Dynamics Ax 2009 SP1 AOS crashes. From what I read online, it is suggested to update the Ax Kernel (only the kernel, not the full RollUp w/ X++ and objects).
It is recommended that you consider regular installation of Kernel rollups in your Microsoft Dynamics AX environments. We find that many times when a customer is experiencing issues with the AOS that installing the latest Kernel hotfix resolves the issue.
In short, applying the fix with the name “_BinaryOnly”.
Is it something that you do periodically on your production environment? Did it reduces the AOS crashes issues? I want to have some experience stories before adding it to our Ax Production environment maintenance procedure.
Thanks in advances!
Regards, Evans Savard
Developer at Cycles Lambert Inc.
