Dynamics AX 2009 - Modify insert into smmActivities from ProjTableWizard?
I am an Dynamics AX newbie, and I need to make a modification to either the ProjTableWizard form code but have not been able to locate where I need to make the change. Essentially what I need to do is modify the part of the Wizard process when creating a sub-project. I need to figure out how a line is inserted into the smmActivities table, so that I can modify the “Activity Purpose” field (prefix it with the Activity Purpose of its parent Project from the ProjTable Form) following the “Finish” button click on the ProjTableWizard form. So far I have been unable to figure out how the ProjTableWizard form is triggering this insert into smmActivities (and how the Purpose field is being populated from the Wizard). Any help would be greatly appreciated! Thanks
