Dynamics ax 2009 is opening in client normal user
I have installed Dynamics AX in Server is “AppServer”
then my client user and “AppServer” is under the ameya domain.
Now I have installed client in a client system, in that system i have done in Administrator login, here in admin, ax is opening,
but in my user login its not opening , getting error, AOS is not establishing ,
any one can help me… to open ax in my user login,
I have created user name in server application and enable so only its opening in user client admin login.
Regards
Sunil
Hi Sunil
Have you installed AX Client in User system after login as Admin?
If yes then Try installing using user login and try than it should work.
regards
Rajesh
