Hi all!
We have a Dynamics AX 2009 environment with 3 different AOS servers.
One issue we have is that the AOS’s don’t seem to sync as they should.
If I stop a period from one AOS, users on the other 2 still see it open for up to one hour.
Anyone know what could cause this?
ATrain
#2
Are they all on the same SP and roll up? Go to Help>About to see the versions, and check that for each AOS.
Basil67
#3
Yes they’re on the same SP (RU6)
I have the same issue here.
the two AOS server don’t sync… is it possible to set up this to sync?
I have 6 AOS on 2 servers, so each server is handle 3 AOS.
Every time i update the application through xpo import, only user who has same AOS session with me, updated.
My temporary solution is :
So far this method works for me and user happy…
