Dynamics Adapter CallStaticClassMethod failed
Hi, I am getting below error message on Role center and Enterprise portal with AX 2009.
An error has occurred during report processing. (rsProcessingAborted) Get Online Help Query execution failed for data set ‘BankAccountAmounts’. (rsErrorExecutingCommand) Get Online Help Exception has been thrown by the target of an invocation. Dynamics Adapter CallStaticClassMethod failed. External component has thrown an exception.
Please help to resolve this error .
Thanks & Regards.
Arun S
PFB the link for the already tested solution - Multiple AOS and single workflow/Business Connector instance in a single server -
http://workflowax.wordpress.com/2009/09/17/running-multiple-aos-on-the-same-box-all-using-workflow/#comment-704
Hi Arun…
I am having the similar issue.
how did u resolve this issue?
Please provide the steps.
Hi Arun,
I am also facing the same issue if you have solution please share with me.
Prabakaran
hi sentha and prabakaran,
u need to process ur cubes
hey guys,i have the same prob,i hope someone will give us the right answer,thanks
hi FELI
you need to process ur cubes via sql business inteligence
thanks very much,great :slight_smile:
