Hello,
I need to create a Document Report similar to a sales Invoice report (e.g Report 206) whereby in the report header I will need to display Customer name/address etc. and the header needs to be dynamic in case the report is being generated for several invoices.
I would like to know if it is still advised to use the GetData/Set data function same as done in Report 206 or I can treat the header inside the report body.
Can someone please advise which is a best practice or standard recommended solution between these 2.
Thank you in advance.
Cheers.
