I have a dialog and I need to add some text at the beginning. it goes something like “Enter only <tablename.colname> characters”
So the text should display the value in that column of the table
dialog.addtext(“Enter only characters”)
I tried using a + operator, but it gives a syntax error “Operands types are not compatible with the operator” which makes sense as the column in question has integer values. Any suggestions?
