is it generally possible to create a XML-Template (with LiveCycle Designer) and to fill it with Data from Navision? This schould allow to create PDF-Documents in NAV with dynamic content.
this can only be done by coding i think.
The possibility to realise it by coding would be all i need [:)]
The idea is: button within a form in Nav to save/send a dynamic PDF.
Are you saying you know it could be done by codes? you dont make sense to me Oldboy.
you can easily design a control button from tools and write the codes in the CAL.
ok thx, my question was whether it is possible or not
