Dynamic Option Values
How can assign Option values to a textbox dynamically (Through Code) ? I have got some Physical properties for each item. When i select the the item, pertaining physical properties of that item to be loaded dynamically into the physical properties textbox as options to select for futher operation… regards rajasekhar venumala
Hi What are the options you want to set? Not all options can be set using Code!
Hai Janus, As we are setting in property called ‘OptionString’ for a text box. I want to set this ‘OptionString’ property of a textbox dynamically through code.
I don’t believe that this can be done. As far as I can tell, the closest you can get is using a table lookup with dynamic values here.
Hi, you can not set dynamic value to optionstring. for the same you can use the lookup functionality.
