Dynamic Nav with sql server over WAN (VPN)
First i’m very new to navision but want to learn more, the story is i want to let end-user can work with NAV over VPN i try to add the rule (allow) in windows firewall having TCP 1434 port for SQL SERVER and also on the sonicwall firewall i do the same
unfortunately when i going to choose database it showing that this server cannot be found
P.S. i vpn directly to this server and i got dns name.
Use Citrix or RDP.
thank you sir but those two solution i know already and i want to avoid to use them.
