Hi My problem is that some captions and title’s om my forms should change, when a different record is being shown. Is there any way of doing this, by changing e.g. the value of a code or text variable. Thanks in advance Henrik Andresen
Look into the property CaptionExpression Lars Strøm Valsted Head of Project and Analysis Columbus IT Partner A/S www.columbusitpartner.com
As for form captions then you can use the CAPTION property of the field to change it. As for field captions on card forms then I will recommend you to use a text box instead of the standard label and have a variable as the source. Best regards, Erik P. Ernst, webmaster
Thank you. It helped
