We are using AX2012 CU3 and we’re having many problems running MRP : we have incorrect actions and early planned orders. Also the system generates duplicate pick lines .
Please can someone help with that . Which settings may be involved? Thanks
You would need to pick one item, look at the demand profile, decide what it should be, adjust the item coverage settings and the master plan settings to reflect this.
Planning will not generate duplicate pick lines, however you can if you do not understand the options when generating the pick.
