i have developed a report for the payment terms in nav 13 from vendor ledger entry, in this i have due date coming from the system whose calculating formula is ‘Document Date + Payment terms code’
Now i don’t want to change the systems working, i just want that in the report i made the due date should be ‘Posting Date+Payment terms code’. can someone please guide how can i do this??
Would help to know the error, when you say it displays and error!
Before you can use any functions in NAV, then you need to know the exact syntax.
Whenever you use functions, where you are not familiar with the correct syntax, is to use the SYMBOL menu from within the C/AL editor. It’s NAV’s old-time intellisense! In the F5 menu it shows you the basic syntax, but just press F1 from within the Symbol menu, then it will show you the full syntax incl. how to use the function.
