Drag and Drop file using Control Add-Ins
An example of Drag and Drop a file in the text box controls. On drag and drop the text box will provide you the path of the file with the filename and extension.
Follow the link below to get more details… Source sample is also available
http://congruentdynamics.blogspot.in/2013/05/drag-and-drop-file-using-control-add.html
