Hi, I have a doubt with these four fields when i see in the cronus company. Exchange Rate Amount ,Relational Exch. Rate Amount, Adjustment Exch. Rate Amount, Relational Adjmt Exch Rate Amt My confusion is exchange rate and adjustment exchange rate is filled with same figures. Actually what is the difference between these two things.
Yeah adjustment exchange rate amount normally r kept same they will be different if u want ur adjustments to be calculated on different rates than the actual exchange rates. The rate mentioned in exchange rate is used for posting only and rate in adjust… is used when u run exchange rate batch job.
