dot matrix cheque printing issue
I’m trying to print the cheque in dot matrix. 1st page is printing properly, but in 2nd page alignment is not coming proper. Please advise if any one knows.
Have you tried with modifying the check layout.
Can you please tell me what to change in that. it is 99 cm. start position 1cm
Change the paper length to 270 mm. Start position is fine. If the allignment issue is coming then you need to modify the check design and keeping the start position and length fixed.
Pranav…
First 20 cheques are printing properly, after 20 onwards it is not printing properly. Some alignment issue is coming. Any idea ?
