at the moment after Posting a Sales Order using option Post&Print → Ship and Invoice. System prints Sales Shipment and Sales Invoice.
How can I change no to print Sales Shipment?
In code? Or it can be done with setup?
Thanks in advance
Thanks in advance
For us I simply commented out the line in CU82…since we NEVER use that report EVER.
I didn’t try it but what if you simply removed the report number from the report selections?
below is where i commented out the code.
I guess I could have added a field to the S&R setup table to turn it on & off easier!
CASE “Document Type” OF “Document Type”::Order: BEGIN
IF Ship THEN BEGIN
SalesShptHeader.“No.” := “Last Shipping No.”;
SalesShptHeader.SETRECFILTER;
//PrintReport(ReportSelection.Usage::“S.Shipment”); << I killed the command!
END;
IF Invoice THEN BEGIN
SalesInvHeader.“No.” := “Last Posting No.”;
SalesInvHeader.SETRECFILTER;
PrintReport(ReportSelection.Usage::“S.Invoice”);
END;
END;
This is a bug in Navision, been there as long as I can remember:
ReportSelection.SETFILTER(“Report ID”,‘<>0’);
ReportSelection.FIND(‘-’);
Should be
// ReportSelection.SETFILTER(“Report ID”,‘<>0’);
That way you can put a blank report entry in the table to mean not print anything.
Thank you both.
where is that code ?
CU82.
