Hi there… I have set-up webshop with a customised client database. It worked fine in the Intranet environment. I then tried to access webshop from the Internet but the following ASP code [mscsPage.SURL] in “home.asp” returns the the following: [Netbios name of server:80] I can access most of webshop with the FQDM but everywhere where it uses that command [Example: Post Function for the form in home.asp for logging in to webshop] it uses the Netbios name which will then not allow you to access that page from the internet. 1. I have set my Secure an Non-Secure Host name to the FQDM in Site Server. 2. I have set my FQDM in domain field in the DNS section in the TCP/IP network configuration. 3. I have set “HostOverride=‘FQDN’” in frontpg.ini. I still get the error… If anybody can think of any suggestions, please help… Stadler
La solucion la tienes en la Consola de Site Server (MMC), comprueba que la Fundación contenga un nombre o una IP que se pueda resolver desde el exterior. Go! SiteServer MMC - Commerce Host Administration - Your Server - Your Site - Right Button (properties).
