Does Dynamics NAV2013 R2 meet WS-standards?
Hi there,
I was asked the question by a customer if NAV 2013 R2’s webservices do meet the following standards: WS-Security, WS-Addressing, WSReliable.
My knowledge on this particular subject is pretty poor, so maybe someone in here could tell me more about it?
Thanks in advance!
Roland
hi,
with nav 2013 you can publish pages and codeunits as (.net) web services. you can reference these web services by an external application (c# app, …). you can also use ssl. standard binding is httpbinding. authentication is windows authentication.
Hi Roland,
Welcome to the the user group, I see this was your first post. [:)]
If the answer Jonathan suggested helped you, then please verify this by selecting “Verify Solution” below his answer. If not, and you’ve found the solution elsewhere, then please share with us, in case someone else are having the same issue. Thank you.
