Does anybody tell me how to be the Master of technical developement in ax 2009?
Means from where to start and what to continuesly follow?
I expected the answer from a experienced technical developer…
Regards
Vijay Parashar
Regards
Vijay Parashar
I do not pretend to be a master but to have good developping skills in AX you must first have a good experience in developping, then you must read all documentation you can find about functional aspect of AX, then, read all developpement books on AX (MorphX it, inside AX 2009, AX 2009 Programming getting started are the best books to start learning) and last but not least, go on forums, talk a maximum with other developpers, try to answer a maximum questions asked on forums, practice a maximum.
Hope ti helps
regards,
Thomas
Hello Thomas,
thanks for giving me a good suggestion…
Regards
Vijay Parashar
Hello Thomas,
Regards
Vijay Parashar
Well said Thomas !
Thats it Vijay, thats enough if you want to excel in codings.
