yes , but here the mouse-up method is in line control method and common is also Linetable, but in my case the mouse up method is in Line control method and common parameter is from header.
for _common parameter , i write code to get it from header , but the _element parameter should be from header , but by default is is from the Line.
Is there any way that i can provide _element parameter from header ?
