Hi,axaptians…
How to attach a document along with a purchase order and sales order…???
Hi,axaptians…
Well to “attach” it you use the document handling butotn and add in the file attaching it to the record. Do you mean this or to print out an attached document after the purchase/sales order?
hiii…
actually i need the print out of the purchase order/sales order…
that tooo i want printout the file having information regarding item’s technical spec documents…
how it is possible???
You can add a document type to a form in the form setup, but I do not beleive adding a word document into the sales order, for example, as a set type, and then printing it will print the word document - there are limitations. I have a feeling there is an add-on that does this, but it would either be this or a modification/customisation.
