Document Handling - AX 2009 (Linking Files to Sales Lines)...?
I am working on document handling in AX 2009,
I need to link some files from a physical folder to the Sales Lines in SalesTable(Form) using Document Handling concept
Requirement :
Sales Id : SO-123456
Line Num : 10000
The Folders are named with Sales Id’s and Line Numbers
The file is located in the below path.
C:\DAX Files \ SO-123456\10000\File1
Now, using X++ code I need to link File1 to Line Number : 10000 of Sales Id : SO-123456
Please let me know you Ideas…
Thanks in Advance…!
Document references are represented by records in DocuRef table.
The action needed for dealing with files depends on document type and its configuration (in Basic > Setup > Document management > Document types). The Class description field refers to a class extending DocuAction class. The standard logic is located especially in DocuActionArchive.add().
