I have a form with Grid, containing 3 columns (coming from tables directly ) and 2 columns are display methods. If one the display method value zero then that row should not be displayed (if display method return value is zero, it should be hidden).
Grid:
Column1 Column2 Column3 Column4 column5
abc 123 wser 1 120
def 32 dfdf 0 12
In the above example since column4 has value 0 this entire should be hidden. Please help me in solving this.
Sorry for my previous post, I mistaken because of fast reading, if you want to filter on display method, please refer on Martin’s answer on the following post
