.dll file for About (Navision)
hai do you know .dll file for about in navison ??
thanx for the answer…
Sorry I didn’t understand you question, can you rephrase it?
Help - About Microsoft Business Solution
That’s we can see Version ID for navision we used, Copyright etc…
I want to know what file that’s fill it…
maybe dll or ocx …
As far as know there is no such dll or ocx. But you can use CU 1 ApplicationManagement to retreive the database version and BUILD.
Code: message('%1 - %2',ApplMgt.ApplicationVersion,ApplMgt.ApplicationBuild);
Messge: NL Dynamics NAV 5.0 - 24199
hmmmmmmmmmmm
i think it’s not for the “About”
I test delete it and then I open about…
it still there…
You can’t control about dialog. Only option that you can customize is Navision version number.
yes… do you know where i can find it?
Recently I spent some time on that issue - and did not find any solution. I even tried to read (binary) the fin.exe-file, but that [of course] does not work all the time.
Change the ApplicationVersion() function in Codeunit 1 to return the text you want.
When you say you tried this and it didn’t work, did you exit and reenter the database? CU 1 is loaded as single instance so I think you need to exit and reenter to see your changes.
In the “About-Window” you get information about the FIN.EXE - version and build.
The window gives info like “Version DK 4.00 SP3 (4.0 SP1)” meaning that the objects are version “…SP3” but the FIN.EXE is “…SP1”.
If you double-click the version-line you get the build-no of the FIN.EXE.
As far as I know it is bot possible to get that info from within NAV.
for example i change applicationversion to be 4 SP 3
in the about navision it will be 4 Sp 3 (Version 4SP1)
→ STILL exist 4 sp 1
i want to change that…
