Displaying fields which changes every time
hello all AX users .
I am currently working on a report generation and have only one PageHeader and one SectionGroup in that .
Lets take an example that i have one Invoice ID and it contains multiple Items invoiced in it .
So the main problem which i am facing is that i am unable to display Item Name of all those invoiced items in a column in the SectionGroup. .
And the link to report opens from one form while i want the data to be fetched from other table say CustInvoiceTrans and relation between these two tables is Invoice ID as described earlier…
How can i get it ?
Please suggest me a solution for it …
hi lalit,
you are trying to fetch the data by using fetch method or display method?
Both the methods i am using still i am unable to find the data …
can you share the code what you are written?
Hi Lalit,
You can fetch the data by creating a display() method in the reports → designs-> Automated/Generated → methods and then simply drag and drop the method in the desired section you want to place your field.
I hope this will be useful…Do share the code that you tried using display() method
To Lilly and Ven,
1)Following is the code i have written in fetch method…
public boolean fetch()
while select _Pier_Table where _Pier_Table.RecId == callerrecord.RecId
this.send(_Pier_Table);
while select _CustInvoiceTrans where _CustInvoiceTrans.InvoiceId == _Pier_Table.InvoiceNumber
this.send(_CustInvoiceTrans);
return true;
2)and following is the display method for returning list of item names for a particular Invoice ID
display str getItemName()
return Itemname;
I want to display this in the body section of the Report …
Please tell me if some changes are to be made in the above described code.
Hi Lilly i have done the same thing as you said but i cannot get the result but for your conveniency,i have written the code as tell me the changes to be made.
here you are using the 2 tables and you are looping through two datasources. its better to avoiding the loops and join the datasources in x++ fashion instead of sql queries.
Hi lalit,
can you tell me from which table you are calling the ItemName() ?
If suppose you are calling from inventTable Table, Then the code is
display EDTname methodName()
return InventTable::find(this.ItemId).itemName;
Thanks Lilly,
Your solution did really worked …
