I am trying to convert an integer (amount) into arabic words.
How can i do this ?
How can i do this ?
I don’t think this functionality exist for Arabic. But similar functionality exists for Spanish, French and Dutch.
For example, have a look at ‘numeralstoTxt_ES’ method under Global class. You may want to create similar method for Arabic.
Hello,
you wont find numeralsToTxt_AR in the standard AX, i did it long time ago by importing .dll into the reference node in AX 2009
you can download the project :
https://skydrive.live.com/?cid=e099f8336aca75ba&sc=documents&uc=1&id=E099F8336ACA75BA!140
good luck!
Hi Anoop,
I’m need to convert amount into arabic and also amount in words,date(Gregorian) into arabic, if you have done this before pls share.
Thanks & Regards,
Ansar.
Do any one have the code pls share. I need it badly.
Ansar.
you will need to implement it by yourself
Hi Noobish,
I implemented the code by myself, but the way of reading Arabic for 10’s and 100’s digit is quite different.
