Master table is caeTeleMaster and the child table is caeTeledetails.For the form caeTeledetails its joining with the tele no.So when i select the telephone number from the child table it has to display the coresponding projid,emplid,dimensions from the master table.So i worte display method for projectid,emplid,dimensions.Here projid,empl id is displaying properly but dimensions is not displaying.Since we have dimension[1],dimension[2] etc…Dimension6.Buit when i write the display method it takes only dimension and the display method doesnt works here.Please let me know how to sort the above issue.
The method must returns the type as declared in header: Dimension[Dimension::code2ArrayIdx(SysDimension::Analysis)] has not the same type as Display Dimension CaeDimension(), I don’t have the caeteleMaster table and I only have 4 dimensions in my AX, so check the extended dataType of the dimension field in caeTeleMaster Table and declare the same in the method header.
