Hello !
I would like to print text on the additional data from the invoice when a specific payment method is selected.
I tested a code on the report of the invoice but not getting results.
All payment methods that will use for this text are registered as B BRASILXXXXX
//BP Deviation Documented
display str printTextMemoFirstPg()
FiscalDocJourLegalTxt_BR legalTxt;
str memo;
int line;
Str lineAux;
CustInvoiceJour custInvoiceJour = FiscalDocJour_BR::findRecId(currentFiscalDocJourRecId).custInvoiceJour();
TaxWithholdSpec taxWithholdSpec;
TmpTaxWithhold tmpTaxWithhold;
CustTable custTable = CustTable::find(custInvoiceJour.OrderAccount);
FiscalDocJour_BR fiscalDocJourLoc;
#define.maxLineChar(60)
#define.maxLine(4)
lineAux = CustTrans::findFromInvoice(fiscalDocJourLoc.InvoiceId, fiscalDocJourLoc.InvoiceAccount).PaymMode;
if (custInvoiceJour.DeliveryIENum_BR != 'ISENTO' && custInvoiceJour.DlvState == 'MA' && custInvoiceJour.InventSiteId == '21')
newmemo += "BASE DE CALCULO DO ICMS REDUZIDA, DE ACORDO COM INCISO XII, § 1, DO ANEXO 1.5, RICMS/MA. ";
if (lineAux LIKE "B BRAS*")
newmemo += "OS BOLETOS REFERENTES AO PARCELAMENTO ACOMPANHAM ESTA NF ";
It has more code below
The same above validating IENUM, DLVSTATE and INVENTSITEID works correctly.
Anyone have any idea, would use the “LIKE” or strScan for example??
