Discrepancy in Purchline.PurchQty & OrderedQty
We are encountering an error where a quantity in the Purchase Order line is not the same as what it appears in Registration or item transaction. I tried to look at the AOS and I found out that the fields Purchline.PurchQty & Purchline.OrderedQty are different. When does this happen & why?
Any inputs will be appreciated.
Bella
According to the AOT’s Help Text property:
QtyOrdered: “Quantity ordered in the inventory unit.”
PurchQty:
So maybe if the inventory unit is a dozen and you ordered 2, then the QtyOrdered would be 2 and the PurchQty would be 24. If you have a test environment, you might want to try that and see if it is correct.
