i have a task, i.e, when checking the table field check box, and disable the filed in other table there is a common field exist in the both tables. can anybody post me the answer.
InventTable form itemNumber will be disabled or not editable when checkin the stopped field in the InventItemSalesSetup table. how to write the method when check the table field and effecting the other table or form field.
u can also use the fieldname.allowedit() or fieldname.enable() on form level…if u hav the relation to both tables then u can write this functionality on the basis of the relation.
