Hello AX Users…
I want to disable the save functionality in Dynamics AX 2009…
Means that if any user clicks the save button or presses Ctrl+S from keyboard,how can i disable that ?
Will nayone please help me for this problem ?
Hello AX Users…
Hi Lalit,
When you want to disable the save option? be specific…is that when you create a new record or specific field, or table???
Actually there is no specific requirement of that button …
Mainly when user creates a new record,the button should be visible but it should not allow the user to save the data…
There is a special condition or validation kept for saving the data and for that i have seperately created a button but that’s not the main issue.
The main thing is that it(Save button and Ctrl+S) should not work at all.
Hi Lalit,
Just refer these links for your solution
http://dynamicsuser.net/forums/p/47787/243634.aspx
http://dynamicsuser.net/forums/p/39416/202378.aspx
If you have any doubts do give a post…
Just comment out the super on the FormDataSource’s write/create methods. That’d do it I believe.
just set allow edit property to no at form datasource properties to NO for the respective datasource…
