thanks alot marshal [:D]
Victor
if the soluton is correct please Verify the soluton
THanks
Marshal.J
[:D]
hi victor,
what marshal meant was that if you could just specify the method which helped you achieve your results, it might help others who have the same kind of problem.so if you are trying out something which is not already specified here then please write the method you are using, and also mark the post which helped you.
thanks,
Exactly correct Shona
Marshal
