Hi, (1) is het possible by means of permissions, properties or C/al to disable the show all option ? (2) Is it possible to disable a field/table filter on a specific field without using c/al (filtergroup) but by means of properties when drilling down on a flowfield ? Thanx in advance.
Not sure but try to play with the following permissions (they’re part of the ALL Role ID) : Object Type Object ID Object Name Read Permission Insert Permission Modify Permission Delete Permission Execute Permission System 3220 View, Table Filter Yes Yes Yes Yes Yes System 3230 View, FlowFilter Yes Yes Yes Yes Yes System 3410 View, Sort Yes Yes Yes Yes Yes Let us know if this has work for you … ###### tarek_demiati@ureach.com
