disable control ax in form
hi every 1
i have ComboBox in form by code in button how can i disable
i have feilde chek_NO
in vb.net
if chek_NO =0
ComboBox.enable = True
else
ComboBox.enable = False
how can change this code to X++
i use here some Fun but not give me result
i try to write
ComboBox_Type.allowEdit() == no
the result
if i write this fun ComboBox_Type.allowEdit( here have massege puplic allowEdit (boolean,value)
and when i compile give masseg wrong
this code
if ( nCoun_Check >= 1 )
{ComboBox_Type.allowEdit() == no ;}
if(enum ==1){
box::warning(“This Report Was Print.”,“PRINT”,“Help text”);
else
box::warning(‘تم طباعة هذا التقرير مسبقاً’,‘الطباعة’);
else
super();
enum =EN_AR.selection() ;
//info(num2str(enum,0,0,0,0));
if(enum ==1)
strnum=“EN” ;
if(enum !=1)
strnum=“AR” ;
CustRptMI.run(Args);
Hi Bas,
ComboBox_Type.allowEdit(false)… it wont allow you to edit the fied…
Naresh Kumar Kolli
thanks it work
but ihave other qus
every form in ax have Autma button (first_one - NEXT - PR - LAST_ONE -NEW-update or delete )
how i link this Condition also with this buttons
or if
if chek_NO =0
i can (update or delete )
else
i cant update or delete
i didnt get you…can you explain again…
hi
any form u create after compile u have 8 button
i mean button tools forms
can i link its with my function
if chek_NO =0
else
and with first_one - NEXT - PR - LAST_ONE
if chek_NO =0
ComboBox_Type.enabled(false)
else
ComboBox_Type.enabled(TRUE)
where i put the function to work
any qus i redy to ans
every form when u create have 8 button (button tools form )
sample have Autma button (first_one - NEXT - PR - LAST_ONE -NEW-update or delete )
if chek_NO =0
i can (update or delete ) in combobox
else
i cant update or delete in combobox
if chek_NO =0
else
ComboBox_Type.enabled(true)
any qua redy to an
any qua redy to an
i mean
i want to stop update or delete data
if chek_NO =0
else
thanks for your help Mr. Naresh Kumar Kolli r
what happen Mr.Naresh Kumar Kolli i did’nt explain to u or what \
i hope to ans me
becu this Very important issue for me
if anyone has a bit of information please help me
[H]
Hi Bas,
In the active method of the form datasource write
if check_no = 0
Datasource_ds.allowEdit(false);
DataSource_ds.allowDelete(false);
Naresh Kolli.
SORY Mr.Naresh Kumar Kolli FOR LATE 2 ANS
I create active method in my Datasource but when i but (.) [:@] after Datasource Name allowEdit function not come
this is my code
public int active()
int ret;
int nCoun_Check ;
CHECKISSUE CHECKISSUE1;
CHECK_NUMBER_TABLE CHECK_NUMBER_TABLE1;
ret = super();
while select * from CHECK_NUMBER_TABLE1
where CHECK_NUMBER_TABLE1.CheckNumber == CheckIssue.CheckNumber
nCoun_Check=CHECK_NUMBER_TABLE1.count_check ;
// info(num2str(nCoun_Check,0,0,0,0));
if (nCoun_Check <= 1)
{ CHECKISSUE1.[:@]
return ret;
pls
show me the wrong in this and write pls the right function
thanks for help i getted
i did’nt add _ds after name datasours
It’s working now…
Naresh Kolli
yes my frind
It’s working now…
thanks
