DimensionSet ID field is Not Updated In Sales Header Table during Upgradation from 2009 to 2016.
Hello,
i have upgraded the database from 2009 to 2016. but Dimension set Id field is 0 for All the reacords.
But shortCutDimension code1 and ShortCutDimension COde 2 field is updated Properly.
in Dimension Set Entry table Dimension Set ID is there.But in sales Header table it is not reflacted.
what can i do for this?
Sounds like you didn’t run the upgrade toolkit?
No,i run the upgrade toolkit .one toolkit i run in 2009 and another toolkit run after i upgrade the databse in 2016.
Ok. Still sounds like something went wrong running this toolkit. Does Ctrl+Shift+D show anything?
What if you create a new order, does it update the Dimension Set ID correctly here?
