Can anybody please explain what is Actually a Dimension is??What is the use of this Dimension table.
Hi Murali,
Check this… u will get the entire solution of that…
http://msdn.microsoft.com/en-us/library/hh167374(v=nav.71).aspx
Hi Murali,
Always mention the version so it will better we can give correct explanation about dimensions as from NAV 2013 onwards concept of dimension is changed.
Hi Amol,
for 2013 r2
You can look at the following link
