dimensions chart
Dear all
Is there any way to make dimensions in ax2012, in a chart structure , the following example will make it more clear:
i’am facing the following scenario in ax 2012 implementation : the company has several departments ex. Accounting - Engineering - Administration and so on , within each department there are some activities which are related only to this department ,
i’ve made the departments and the activities , dimensions , the following is the problem : in the general journal transaction , when the user selects a department , i need only the activities which are related to this department to appear in the activities segment , not all the activities .
how could i achieve this ?
h_mosa
You can use advanced rule structure to achieve this.
Pranav…
